Enable SPB-PIM Gateway on a Brouter port.
- In the Device Physical View tab, select the port you need to configure.
 - Click IP.
 - Click the SPB-PIM-GW tab.
 - Select the Enable check box to enable SPB-PIM Gateway on a Brouter port interface.
 - Click Apply.
SPB-PIM-GW field descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
 Name  |
 Description  |
 Enable  |
 Enables SPB-PIM Gateway on the interface. The default is disabled.  |
 OperState  |
 Displays the current operational state of this SPB-PIM Gateway interface.  |
 Address  |
 Displays the primary IP address of this router on this SPB-PIM Gateway interface.  |
 AddressMask  |
 Displays the primary IP address mask of this router on this SPB-PIM Gateway interface.  |
 HelloInterval  |
 Configures the PIM HELLO transmission interval.  |
 JoinPruneInterval  |
 Configures the PIM JOIN PRUNE transmission interval.  |
