                                 IEEE standard  |
                                 Description  |
                                 802.1AB  |
                                 LLDP  |
                                 802.1ag  |
                                 Connectivity Fault Management  |
                                 802.1ah  |
                                 Provider Backbone Bridging  |
                                 802.1aq  |
                                 Shortest Path Bridging (SPB)  |
                                 802.1AX  |
                                 Link Aggregation  |
                                 802.1D  |
                                 MAC Bridges  |
                                 P802.1p  |
                                 Traffic Class Expediting and Dynamic Multicast Filtering  |
                                 802.1Q  |
                                 Virtual LANs  |
                                 802.1s  |
                                 Multiple Spanning Trees  |
                                 802.1t  |
                                 802.1D Technical & Editorial Corrections  |
                                 802.1w  |
                                 Rapid Spanning Tree Protocol (RSTP)  |
                                 802.1X-2010  |
                                 Port-based Network Access Control (NAC)  |
                                 802.3 CSMA/CD Ethernet ISO/IEC 8802  |
                                 International Organization for Standardization (ISO) /International Eletrotechnical Commission (IEC) 8802-3  |
                                 802.3ab  |
                                 1000 Mbps Operation, implemented as 1000BASE-T Copper  |
                                 802.3ac  |
                                 Carrier sense multiple access with collision detection (CSMA/CD) frame extensions for Virtual Bridged Local Area Networks (VLAN) tagging on 802.3 networks  |
                                 802.1AE  |
                                 MAC Security  |
                                 802.3ae  |
                                 10 Gbps Operation, implemented as 10GBASE-X SFP+  |
                                 802.3af 802.3at 802.3bt (Type 3 and Type 4)  |
                                 Power over Ethernet (PoE)  |
                                 802.3az  |
                                 Energy Efficient Ethernet (EEE)  |
                                 802.3ba  |
                                 40 Gbps and 100 Gbps Operation, implemented as 40GBASE-QSFP+ and 100GBASE-QSFP28  |
                                 802.3x  |
                                 Full Duplex & Flow Control  |
                                 802.3z  |
                                 1000 Mbps Operation, implemented as 1000BASE-X SFP  |
                                 ANSI/TIA-1057  |
                                 LLDP-MED  |
