Create an IPv6 VPN Instance
The VRF must exist.
Create an IPv6 VPN instance to advertise IPv6 routes from a VRF to Shortest Path Bridging MAC (SPBM) network. For more information about Layer 3 Virtual Services Networks (VSNs) and SPBM, see Layer 3 VSN Configuration.
Create and enable IPv6 VPN instance:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf vrfred
Switch:1(router-vrf)#ipv6 ipvpn
Switch:1(router-vrf)#i-sid 100
Switch:1(router-vrf)#ipv6 ipvpn enable
Switch:1(router-vrf)#show ipv6 ipvpn
                                        IPv6 IPVPN
VRF Name            VRF ID   IPv6 IPVPN   IPv4 IPVPN   I-SID        I-SID Name
vrfred              2        enabled      disabled     5555         ISID-5555
1 out of 1 Total IPv6 L3 VSN, 1 active IPv6 and 0 active IPv4 displayed.
	Variable definitions
Use the data in the following table to configure the ipv6 ipvpn command.
 Variable  |
 Value  |
 enable  |
 Enables IPv6 IPVPN. The default is disabled.  |
Use the data in the following table to configure the i-sid command.
 Variable  |
 Value  |
 <0–16777215>  |
 Assigns an I-SID to the VRF being configured.  |
Use the data in the following table to configure the show ipv6 ipvpn command.
 Variable  |
 Value  |
 vrf WORD<1–16>  |
 Specifies the VRF name.  |
 vrfids WORD<0–512>  |
 Specifies the VRF ID.  |
