Configure Simple Network Management Protocol (SNMP) to define or modify the SNMP settings, and specify the security level for SNMP communications.
Enable the generation of SNMP traps. Configure the contact information for the system. Configure hosts to receive SNMP notifications:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#snmp-server authentication-trap enable Switch:1(config)#snmp-server contact xxxx@company.com Switch:1(config)#snmp-server host 192.0.2.16 port 1 v1 SNMPv1 filter SNMPfilterv1
The following table defines parameters for the snmp-server command.
Variable |
Value |
authentication-trap {enable} |
Enables generation of SNMP server authentication traps. |
contact WORD<0-255> |
Changes the sysContact information for the switch. WORD<0-255> is an ASCII string from 0–255 characters (for example, a phone extension or email address). |
host WORD<1-256> [port <1-65535>] {v1 WORD<1-32>|v2c WORD<1-32> [inform] [timeout <1-2147483647>][retries <0-255>][mms <0-2147483647>]]|v3 {noAuthPriv|authNoPriv|authPriv} WORD<1-32> [inform [timeout <1-2147483647>][retries <0-255>]]} [filter WORD<1-32>] |
Configures hosts to receive SNMP notifications.
location WORD<0-255> |
Configures the sysLocation information for the system. <WORD 0-255> is an ASCII string from 0–255 characters. |
login-success-trap {enable} |
Enables generation of SNMP server login-success traps. |
name WORD<0-255> |
Configures the sysName information for the system. <WORD 0-255> is an ASCII string from 0–255 characters. SNMP system name is derived from the global system name that is synchronized with SNMP system name, until the SNMP system name is manually configured. |
notify-filter WORD<1-32> WORD<1-32> |
Creates a new entry in the notify filter table. The first WORD<1-32> specifies the filter profile name, and the second WORD<1-32> specifies the subtree object identifier (OID). |
