Configure egress port-based shaping to bind the maximum rate at
which traffic leaves the port.
- In the Device Physical
View tab, select a port.
 - In the navigation pane,
expand the  folders.
 - Click General.
 - Click the Interface tab.
 - From EgressRateLimitState, select enable.
 - In the EgressRateLimit box, type an egress rate limit in kilobits per second (Kb/s).
 - Click Apply.
