View IPv6 DHCP statistics to manage network performance.
 - Select DHCP Relay.
 - Select the Interfaces Stats tab.
Interfaces Stats Field Descriptions
Use the data in the following table to use the Interfaces Stats tab.
                                 Name  |
                                 Description  |
                                 IfIndex  |
                                 Identifies the physical interface.  |
                                 NumRequests  |
                                 Shows the number of DHCP and BootP requests on this interface.  |
                                 NumReplies  |
                                 Shows the number of DHCP and BootP replies on this interface.  |
