Configure Subnet Routers
Use this procedure to configure the Subnet Routers tab in EDM for
        a DHCP subnet.
- In the navigation pane, select .
 - Select the Subnet tab.
 - Select the applicable subnet and select Extra.
 - Select the Subnet Routers tab.
 - In the Subnet IP field, enter the subnet network address.
 - In the Subnet Mask field, enter the subnet mask.
 - In the IP field, enter the router IPv4 address.
 - Select Insert.
 - Repeat these steps if you want to add additional router addresses.
Subnet Routers Field Descriptions
Use the data in the following table to configure the Subnet Routers tab for a DHCP subnet.
| Name | Description |
| Subnet IP | Specifies the network address of the DHCP subnet. |
| Subnet Mask | Specifies the subnet mask of the DHCP subnet. |
| IP | Specifies the IPv4 address for the subnet router. You can assign up to eight router addresses. |
