Configure ACE IPv6 source address entries to have the filter look for specific source IP addresses.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click IPv6.
 - Click the Source Address tab.
 - Click Insert.
 - In the Oper field, select the operation type.
 - In the List field, enter the source IP address.
 - In the OperMask field, enter the operation mask value.
 - Click Insert.
Source Address field descriptions
Use the data in the following table to use the Source Address tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 List  |
 Specifies the source IP address.  |
 OperMask  |
 Specifies the mask value for the source IP address.  |
