Configure the SPB-PIM Gateway interface parameters on a VLAN.
 - Click VLANs.
 - Select a row from the VLAN and click the IP tab.
 - Click the SPB-PIM-GW tab.
 - In the HelloInterval field, type the hello transmission interval.
 - In the JoinPruneInterval field, type the join prune transmission interval.
 - Click Apply.
SPB-PIM-GW field descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
 Name  |
 Description  |
 OperState  |
 Displays the current operational state of this SPB-PIM Gateway interface.  |
 Address  |
 Displays the primary IP address of this router on this SPB-PIM Gateway interface.  |
 AddressMask  |
 Displays the primary IP address mask of this router on this SPB-PIM Gateway interface.  |
 HelloInterval  |
 Configures the PIM HELLO transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global SPB-PIM Gateway HELLO interval setting. Setting the HELLO Interval to 0 causes the neighbors to never expire its neighborship with this local SPB-PIM Gateway interface.  |
 JoinPruneInterval  |
 Configures the PIM JOIN PRUNE transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global level JOIN PRUNE transmission interval setting.  |
