Perform this procedure to view information about the USB port on the switch.
- In the Device Physical View, select the USB port.
- Select USB Port.
- Select the General tab.
General field descriptions
Use the data in the following table to use the General tab.
Name |
Description |
UsbStatus |
Displays the current status of USB storage: either present or notPresent. |
UsbDescription |
Displays a description of the USB storage. |
