View the DvR backbone entries (redistributed host routes) learned from all Controllers in all DvR domains.
DvR backbone entries can be viewed only on a Controller. Viewing backbone entries is not applicable on a Leaf node.
Ensure that you enable DvR globally on the node.
View all DvR backbone entries:
Switch:1#show dvr backbone-entries
                                               DVR Backbone-Entries
                HOST                L3VSN      L2VSN      DOMAIN
IP-ADDRESS      MAC-ADDRESS         ISID       ISID       ID      ADV-CONTROLLER      NEXT HOP          AREA     AREA-NAME
40.0.1.2        b0:ad:aa:4c:55:00   0          40400      255     Ctrl-2:8200:122     Ctrl-1:8400:121   HOME     area-0.00.20
40.0.1.2        b0:ad:aa:4c:55:00   0          40400      255     Ctrl-1:8400:121     Ctrl-1:8400:121   HOME     area-0.00.20
40.0.1.3        b0:ad:aa:43:31:00   0          40400      255     Ctrl-1:8400:121     Ctrl-2:8200:122   HOME     area-0.00.20
40.0.1.3        b0:ad:aa:43:31:00   0          40400      255     Ctrl-2:8200:122     Ctrl-2:8200:122   HOME     area-0.00.20
Home: 4 out of 4 Total Num of DVR Backbone Routes displayed
View DvR backbone entries on a specific DvR Controller:
Switch:1#show dvr backbone-entries adv-controller Ctrl-2:8200:122
40.1.1.3        b0:ad:aa:43:31:00   0          40401      255     Ctrl-2:8200:122     Ctrl-2:8200:122  HOME     area-0.00.20
Home: 2 out of 2 Total Num of DVR Backbone Routes displayed
View DvR backbone entries for a specific host MAC address:
Switch:1#show dvr backbone-entries host-mac-address  b0:ad:aa:4c:55:00
View DvR backbone entries for a specific IP address:
In this example, you enter IP address 40.0.1.0 to display backbone entries for IP addresses 40.0.1.2 and 40.0.1.3.
Switch:1#show dvr backbone-entries ipv4 40.0.1.0
40.1.1.3        b0:ad:aa:43:31:00   0          40401      255     Ctrl-2:8200:121    Ctrl-2:8200:122  HOME     area-0.00.20
View DvR backbone entries for a specific L3 VSN I-SID:
Switch:1#show dvr backbone-entries l3isid 0
View DvR backbone entries for a specific next hop node:
Switch:1#show dvr backbone-entries next-hop Ctrl-1:8400:121
View DvR backbone entries where the next hop nodes are displayed as MAC addresses:
Switch:1#show dvr backbone-entries nh-as-mac
40.0.1.2        b0:ad:aa:4c:55:00   0          40400      255     Ctrl-2:8200:122  00:bb:00:00:81:21   HOME     area-0.00.20
40.0.1.2        b0:ad:aa:4c:55:00   0          40400      255     Ctrl-1:8400:121  00:bb:00:00:81:21   HOME     area-0.00.20
Variable definitions
Use the data in the following table to use the show dvr backbone entries command.
 Variable  |
 Value  |
 adv-controller WORD<1-255>  |
 Specifies the system name of the advertising Controller.  |
 domain-id <1-255>  |
 Specifies the domain ID of the DvR backbone entry. The range is 1 to 255.  |
                             home  |
                             Display the DvR backbone entries for the home instance.  |
 host-mac-address 0x00:0x00:0x00:0x00:0x00:0x00  |
 Specifies the host MAC address of the DvR backbone entry.  |
 ipv4 {A.B.C.D}  |
 Specifies the IP address (IPv4) of the DvR backbone entry.  |
 l2isid <1-16777215>  |
 Specifies the Layer 2 I-SID of the DvR backbone entry. The range is 1 to 16777215.  |
 l3isid <0-16777215>  |
 Specifies the Layer 3 I-SID of the DvR backbone entry. The range is 0 to 16777215.  |
 next-hop WORD<1-255>  |
 Specifies the system name of the next hop node.  |
 nh-as-mac  |
 Specifies the MAC address of the next hop node instead of the system name.  |
                             remote  |
                             Display the DvR backbone entries for the remote instance.  |
