Creating an IPv4 ACL
Create an ACL to specify an ordered list of ACEs, or filter rules.
Do not configure IPv4 egress ACL filters on NNI ports because the system-generated egress vIST filter rules and the user-created IPv4 egress rules use the same filter hardware.
Variable definitions
Use the data in the following table to use filter acl command.
 Variable  |
 Value  |
 <acl-id>  |
 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
 enable  |
 Enables the ACL state, and all associated ACEs. Enabled is the default state.  |
 matchType <both|terminatingNNIOnly|uniOnly>  |
 For inVsn ACL types, specifies the match type to associate with
the ACL. Valid options are:
 The default value is both.  |
 name WORD<0-32>  |
 Specifies an optional descriptive name for the ACL.  |
 type <inVlan|inPort|outPort|inVsn>  |
 Specifies the ACL type. The values inVlan, inPort, and inVsn are ingress ACLs, and outPort is an egress ACL. A port-based ACL has precedence over a VLAN-based ACL.  |
