Configure a specific I-SID and customer VLAN ID to use as the management I-SID when a port is in the Auto-sense FA PROXY or FA PROXY RING state.
The switch creates this I-SID dynamically and uses it instead of the onboarding I-SID.
The following table defines parameters for the auto-sense fa proxy management command.
Variable |
Value |
c-vid <1-4094> |
Specifies the customer VLAN ID. |
i-sid <1-15999999> |
Specifies the service instance identifier (I-SID). |
