Use this procedure to view IPsec statistics and counter values at the switch level for all IPsec-enabled interfaces.
 - Click IPSec.
 - Click the Global Stats tab.
Global Stats Field Descriptions
Use the data in the following table to use the Global Stats tab.
 Name  |
 Description  |
 InSuccesses  |
 Specifies the number of ingress packets IPsec successfully carries.  |
 InSPViolations  |
 Specifies the number of ingress packets IPsec discards since boot time because of a security policy violation.  |
 InNotEnoughMemories  |
 Specifies the number of ingress packets IPsec discards since boot time because not enough memory is available.  |
 InAHESPReplays  |
 Specifies the number of ingress packets IPsec discards since boot time because the AH replay check fails.  |
 InESPReplays  |
 Specifies the number of ingress packets IPsec discards since boot time because the ESP replay check fails.  |
 InAHFailures  |
 Specifies the number of ingress packets IPsec discards since boot time because the AH authentication check fails.  |
 InESPFailures  |
 Specifies the number of ingress packets IPsec discards since boot time because the ESP authentication check fails.  |
 OutSuccesses  |
 Specifies the number of egress packets IPsec successfully carries since boot time.  |
 OutSPViolations  |
 Specifies the number of egress packets IPsec discards since boot time because a security policy violation occurs.  |
 OutNotEnoughMemories  |
 Specifies the number of egress packets IPsec discards since boot time because not enough memory is available since boot time.  |
 generalError  |
 Specifies a general error.  |
 InAHSuccesses  |
 Specifies the number of ingress packets IPsec carries because the AH authentication succeeds.  |
 OutAHSuccesses  |
 InESPSuccesses  |
 Specifies the number of ingress packets IPsec carries since boot time because the ESP authentication succeeds.  |
 OutESPSuccesses  |
 OutKBytes  |
 Specifies the total number of kilobytes on egress.  |
 OutBytes  |
 Specifies the total number of bytes on egress.  |
 InKBytes  |
 Specifies the total number of bytes on ingress.  |
 InBytes  |
 TotalPacketsProcessed  |
 Specifies the total number of packets processed.  |
 TotalPacketsByPassed  |
 Specifies the total number of packets bypassed.  |
 OutAHFailures  |
 Specifies the number of egress packets IPsec discards since boot time because the AH authentication check fails.  |
 OutESPFailures  |
 Specifies the number of egress packets IPsec discards since boot time because the ESP authentication check fails.  |
 InMD5Hmacs  |
 Specifies the number of inbound HMAC MD5 occurrences since boot time.  |
 InSHA1Hmacs  |
 Specifies the number of inbound HMAC SHA1 occurrences since boot time.  |
 InAESXCBCs  |
 Specifies the number of inbound AES XCBC MAC occurrences since boot time.  |
 InAnyNullAuth  |
 Specifies the number of inbound null authentication occurrences since boot time.  |
 In3DESCBCs  |
 Specifies the number of inbound 3DES CBC occurrences since boot time.  |
 InAESCBCs  |
 Specifies the number of inbound AES CBC occurrences since boot time.  |
 InAESCTRs  |
 Specifies the number of inbound AES CTR occurrences since boot time.  |
 InAnyNulEncrypt  |
 Specifies the number of inbound null occurrences since boot time. Used for debugging purposes.  |
 OutMD5Hmacs  |
 Specifies the number of outbound HMAC MD5 occurrences since boot time.  |
 OutSHA1Hmacs  |
 Specifies the number of outbound HMAC SHA1 occurrences since boot time.  |
 OutAESXCBCs  |
 Specifies the number of outbound AES XCBC MAC occurrences since boot time.  |
 OutInAnyNullAuth  |
 Specifies the number of outbound null authentication occurrences since boot time.  |
 Out3DESCBCs  |
 Specifies the number of outbound 3DES CBC occurrences since boot time.  |
 OutAESCBCs  |
 Specifies the number of outbound AES CBC occurrences since boot time.  |
 OutAESCTRs  |
 Specifies the number of outbound AES CTR occurrences since boot time.  |
 OutInAnyNullEncrypt  |
 Specifies the number of outbound null occurrences since boot time. Used for debugging purposes.  |
