Clear ACL Statistics
Clear default ACL statistics if you no longer require previous statistics.
The ACL statistics do not support security action on some hardware platforms.
Use the information in the following table to use the clear filter acl statistics command.
 Variable  |
 Value  |
 <acl-id>  |
 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
 <ace-id>  |
 Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.  |
