You must globally enable ICMP Router Discovery.
Change the VRF instance as required. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View.
Use this procedure to configure Router Discovery on a port. When enabled, the port sends Router Discovery advertisement packets.
- In the Device Physical View tab, select a port.
 - Click IP.
 - Click the Router Discovery tab.
 - To enable Router Discovery, select AdvFlag.
 - Configure other parameters as required for proper operation.
 - Click Apply.
Router Discovery field descriptions
Use the data in the following table to use the Router Discovery tab.
 Name  |
 Description  |
 AdvAddress  |
 Specifies the destination IP address used for broadcast or multicast router advertisements sent from the interface. The accepted values are the all-systems multicast address 224.0.0.1, or the limited-broadcast address 255.255.255.255. The default value is 255.255.255.255.  |
 AdvFlag  |
 Indicates whether (true) or not (false) the address is advertised on the interface. The default value is True (advertise address).  |
 AdvLifetime  |
 Specifies the time to live value (TTL) of router advertisements (in seconds) sent from the interface. The range is MaxAdvInterval to 9000 seconds. The default value is 1800 seconds.  |
 MaxAdvInterval  |
 Specifies the maximum time (in seconds) that elapses between unsolicited broadcast or multicast router advertisement transmissions from the interface. The range is 4 seconds to 1800 seconds. The default value is 600 seconds.  |
 MinAdvInterval  |
 Specifies the minimum time (in seconds) that elapses between unsolicited broadcast or multicast router advertisement transmissions from the interface. The range is 3 seconds to MaxAdvInterval. The default value is 450 seconds.  |
 PreferenceLevel  |
 Specifies the preference value (a higher number indicates more preferred) of the address as a default router address relative to other router addresses on the same subnet. The accepted values are –2147483648 to 2147483647. The default value is 0.  |
