Reenable a port that has been operationally disabled by SLPP Guard.
            You cannot reenable a disabled port if the timer count has not reached its timeout
                value. Either wait until it reaches the timeout or disable SLPP Guard for that port
                and then re-enable it.
- In the navigation pane, expand the  folders.
 - Click SLPP.
 - Click the SLPP Guard tab.
 - In the port row, double-click the cell in the Enabled column.
                Select true from the drop-down
                    list to enable SLPP Guard, or false to disable SLPP Guard for the port.
 - Optional: In the port row, double-click the
cell in the Timeout column.
 - Optional: Type a value in the Timeout field.
 - Click Apply.
 - On the toolbar, click Refresh to
update the work area data display.
