Perform this procedure to display Level 1 remote area information. Remote Intermediate-System-to-Intermediate-System (IS-IS) provides support for hierarchical routing, which enables the system to partition large routing domains into smaller areas. Remote IS-IS uses a two-level hierarchy, dividing the domain into multiple Level 1 areas and one Level 2 area. The Level 2 area serves as backbone of the domain, connecting to all the Level 1 areas.
Important
The IEEE 802.1aq standard currently only defines the use of one hierarchy, Level 1. Level 2 function is disabled.
 - Select IS-IS Remote.
 - Select the L1 Area tab.
L1 Area Remote Field Descriptions
Use the data in the following table to use the L1 Area Remote tab.
 Name  |
 Description  |
                                 AreaAddr  |
                                 Specifies an area address reported in a Level 1 link-state packets (LSP) that the system generates or receives through the Intermediate System.  |
