Configure DHCP Subnet
Use this procedure to configure the DHCP Server Subnet tab in EDM.
  1. In the navigation pane, select Configuration > IP > DHCP Server.
  2. Select the Subnet tab.
  3. In the Subnet IP field, enter the subnet network address.
  4. In the Subnet Mask field, enter the mask.
  5. In the Pool Range Start field, enter the IPv4 address that marks the start of the address range.
  6. In the Pool Range End field, enter the IPv4 address that marks the end of the address range.
  7. In the Lease Duration field, enter the expiration timer, in seconds, for this subnet.
  8. In the TFTP Server IP field, enter the IPv4 address of the TFTP server that you want to assign to the subnet.
  9. In the TFTP Server Name field, enter the server name of the TFTP server that you want to assign to the subnet.
  10. In the TFTP Bootfile Name field, enter the filename of the boot image that you want to assign to clients in the subnet.
  11. Select Insert.
  12. Repeat this procedure if you want to configure another subnet.
Subnet Field Descriptions
Use the data in the following table to configure the Subnet tab for DHCP Server.
Name Description
Subnet IP Assigns the network address of the DHCP subnet.
Subnet Mask Assigns the subnet mask for the DHCP subnet.
Pool Range Start Assigns the starting address in the IP address range.
Pool Range End Assigns the ending IP address in the address range. This address must be higher than the starting address.
Lease Duration Assigns the lease expiration timer in seconds.
TFTP Server IP Specify the IP address of the TFTP server that the subnet will use.
TFTP Server Name Specify the server name of the TFTP server that the subnet will use.
TFTP Bootfile Name Specify the file name of the TFTP boot image that the subnet will use
