Perform this procedure to view PoE Powered Device (PD) information for remote LLDP-MED on specific ports.
 - Click Port MED.
 - Click the Neighbor PoE PD tab.
Neighbor PoE PD Field Descriptions
 Name  |
 Description  |
 TimeMark  |
 Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.  |
 LocalPortNum  |
 Specifies the port on which the remote LLDP-MED information is received.  |
 Index  |
 Specifies the particular connection instance that is unique to the remote LLDP-MED.  |
 PDPowerReq  |
 Specifies the value of the power required by a PD LLDP-MED connected remotely to the port.  |
 PDPowerSource  |
 Specifies the power source being utilized by the PD LLDP-MED.
 PDPowerPriority  |
 Specifies the priority of the PD LLDP-MED connected remotely to the port, for more information, see RFC 3621.
