Configure ACE IP fragmentation entries to have the filter look for packets with the fragmentation flag.
The ACL exists.
The ACE exists.
Fragmentation field descriptions
Use the data in the following table to use the Fragmentation tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 Specifies the logical operator for the ACE IP options. Any is the only option.  |
 Fragmentation  |
 Specifies the IP fragmentation bits to match from the IP header:
