Perform this procedure to enable Virtual Link Aggregation Control Protocol (VLACP) on an Extreme Integrated Application Hosting (IAH) port. VLACP periodically checks the end-to-end health of a point-to-point connection.
- In the navigation tree, expand .
- Select the IAH port you want to configure.
- Select the VLACP tab.
- Select AdminEnable.
- Configure the other parameters as required.
- Select Apply.
VLACP Field Descriptions
Use data in the following table to configure the VLACP tab.
Name |
Description |
AdminEnable |
Enables VLACP on the Extreme Integrated Application Hosting (IAH) port. The default is disabled. |
OperEnable |
Specifies the VLACP operational status for the IAH port. The default is false. |
FastPeriodicTimer |
Specifies the number of milliseconds between periodic transmissions using short timeouts. Set the same value for all LACP enabled IAH ports. The default value is 200. |
SlowPeriodicTimer |
Specifies the number of milliseconds between periodic transmissions using long timeouts. Set the same value for all LACP enabled IAH ports. The default value is 30000. |
Timeout |
Specifies the timeout control value. The default value is long. |
TimeoutScale |
Specifies the value used to calculate timeout duration from the periodic time for all VLACP enabled IAH ports. Timeout = PeriodicTime x TimeoutScale. The default value is 3. |
EtherType |
Specifies the VLACP protocol identification. The ID is in hexadecimal format. The default value is 0x8103. |
EtherMacAddress |
Specifies the multicast MAC address exclusively used for VLACPDUs. |
PortState |
Specifies the VLACP port state. |
