Perform the following procedure to display information about all primary IP interfaces configured on the device.
This command displays only primary IP interfaces. To view Secondary IP Interfaces, see Display All Configured IP Addresses.
Show the primary IP interfaces and addresses on the device:
Switch:1>show ip interface
IP Interface - GlobalRouter
INTERFACE IP NET ADMIN OPER VLAN BROUTER IPSEC IP
ADDRESS MASK STATUS STATE ID PORT STATE NAME
Port1/2 192.0.2.1 255.255.255.0 enable up 20 true disable
Vlan10 198.51.100.0 255.255.255.0 disable down 10 false disable
All 2 out of 2 Total Num of IP interfaces displayed
Use the data in the following table to show ip interface command.
Variable |
Value |
gigabitethernet |
Displays IP interface information for Gigabit Ethernet ports. |
vrf |
Displays interface information for a particular VRF. |
vrfids |
Displays interface information for particular VRF IDs. |
