Use the following procedure to display the port VLAN information.
Switch:#enable
Switch:1#show interfaces gigabitethernet vlan
                                   Port Vlans
PORT          DISCARD DISCARD   DEFAULT VLAN         PORT     UNTAG    DYNAMIC  UNTAG
NUM   TAGGING TAGFRAM UNTAGFRAM VLANID  IDS          TYPE     DEFVLAN  VLANS    VLANS
1/1   disable false   false     1       1            normal   disable  P        1
1/2   enable  false   false     1       1,3,10       normal   disable  P        1,10
1/3   enable  false   false     1       1,10,20      normal   disable  P
The following table defines parameters for the show interfaces command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
