Perform this procedure to specify the RSTP mode.
Configure Rapid Spanning Tree Protocol version:
Switch:1(config)# spanning-tree rstp version rstp
Use the data in the following table to use the spanning-tree rstp version command.
                             Variable  |
                             Value  |
                             rstp version {rstp|stp-compatible}  |
                             Sets the version to RSTP or to STP compatible. The default is RSTP.  |
