View topology status information (which includes MIB status information) to view the configuration status of the SynOptics Network Management Protocol (SONMP) on the system.
 - Click Topology.
 - Click the Topology tab.
Topology field descriptions
Use the data in the following table to use the Topology tab.
 Name  |
 Description  |
 IpAddr  |
 Specifies the IP address of the device.  |
 Status  |
 Indicates whether topology (SONMP) is on or off for the device.  |
 NmmLstChg  |
 Specifies the value of sysUpTime, the last time an entry in the network management MIB (NMM) topology table was added, deleted, or modified, if the table did not change since the last cold or warm start of the agent.  |
 NmmMaxNum  |
 Specifies the maximum number of entries in the NMM topology table.  |
 NmmCurNum  |
 Specifies the current number of entries in the NMM topology table.  |
