The virtual services running on a Virtual Machine (VM) require a console for configuration and monitoring purposes.
Perform this procedure to access the virtual service console port for the specific VM.
This command also works in Global Configuration mode but does not display if you use the question mark (?) help in that mode.
Switch:1>enable Switch:1#virtual-service tpvm console
The following table defines parameters for the virtual-service command.
                                 Variable  |
                                 Value  |
                                 WORD<1-128>  |
                                 Specifies the virtual service name.  |
                                 console  |
                                 Accesses the console for the specific virtual service.  |
