Configure CFM Nodal MEP
Use this procedure to configure the CFM nodal Maintenance Endpoint (MEP). The Nodal MEP provides traceability and troubleshooting at the system level for a given B-VLAN. The Nodal B-VLAN MEPs created on the CP and function as if they are connected to the virtual interface of the given B-VLAN. Because of this they are supported for both port and MLT based B-VLANs.
Nodal MPs provide both MEP and Maintenance Intermediate Point (MIP) functionality for SPBM deployments. Nodal MPs are associated with a B-VLAN and are VLAN encapsulated packets. Each node (chassis) has a given MAC address and communicates with other nodes. The SPBM instance MAC address is used as the MAC address of the Nodal MP.
You must configure a CFM MD, MA, and MEP.
 - Click VLANs.
 - Click the Advanced tab.
 - Select a VLAN with a type of spbm-bvlan.
 - Click Nodal.
 - In the NodalMepList field, specify the nodal MEPs to add to the VLAN.
 - Click Apply.
Nodal MEP/MIP Field Descriptions
Use the data in the following table to use the Nodal MEP/MIP tab.
 Name  |
 Description  |
 NodalMepList  |
 Specifies the nodal MEPs to add to the VLAN, in the format <mdName.maName.mepId>, for example md10.ma20.30.  |
 NumOfNodalMep  |
 Indicates the number of nodal MEPs assigned to this VLAN.  |
 NodalMipLevelList  |
 Specifies a MIP level list.  |
 NumOfNodalMipLevel  |
 Indicates the number of nodal MIP levels assigned to this VLAN that allows MIP functionality to be enabled on a per level per VLAN basis.  |
