Perform this procedure to enable Energy Saver on a specific port or range of ports.
If you have previously enabled Energy Saver globally, you must disable it globally before enabling Energy Saver on individual ports.
If you have previously enabled Efficiency Mode, you must disable it before enabling Energy Saver on individual ports.
Enable energy savings on slot 1 port 2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 1/2 Switch:1(config-if)#energy-saver port 1/2 enable
What to do next
Configure an Energy Saver schedule.
The following table defines parameters for the energy-saver command.
 Variable  |
 Value  |
 enable  |
 Enables energy savings on ports. The default is disabled.  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
