Use the following commands to check IGMP information.
enable
show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>[vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the output displays routed-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
Display IGMP information for Layer 3 VSN with IP multicast over Fabric Connect:
Switch:#enable
Switch:1#show ip igmp interface vrf green
Igmp Interface - GlobalRouter
QUERY OPER QUERY WRONG LASTMEM
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE
V100 125 activ 2 2 0.0.0.0 100 0 0 2 10 routed-spb
1 out of 1 entries displayed
Switch:1#show ip igmp interface vlan 2
Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SNOOP SSM UPnP FAST FAST
ID INTVL MAX MEMB SNOOP ENABLE ORIGIN SNOOP FILTER LEAVE LEAVE
RESP QUERY ENABLE ENABLE ENABLE ENABLE PORTS
2 125 100 2 2 10 false false RADIUS false true false
VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP
ID QUERIER QUERIER DOWNGRADE MODE HOSTS FILTER
ENABLE ADDRESS VERSION TRACKING ADDRESS
2 false 0.0.0.0 enable disable disable 192.0.2.3/24
Switch:1# show ip igmp sender vrf vrf1
IGMP Sender - VRF vrf1
PORT/
GRPADDR IFINDEX MEMBER MLT STATE L2ISID SCOPEISID DATAISID
224.1.1.4 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 16000001
224.1.1.4 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 16000004
224.1.1.6 Vlan 10 192.2.0.1 1/18/1 FILTERED 0 10010 16000010
224.1.1.7 Vlan 10 192.2.0.1 1/18/1 FILTERED 0 10010 16000009
224.1.1.8 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 210
5 out of 5 entries displayed
Switch:1# show ip igmp group vrf green
IGMP Group - GlobalRouter
GRPADDR INPORT MEMBER EXPIRATION TYPE
233.252.0.1 V501-1/16 192.2.0.1 204 Dynamic
233.252.0.2 V501-1/16 192.2.0.1 206 Dynamic
233.252.0.3 V501-1/16 192.2.0.1 206 Dynamic
233.252.0.4 V501-1/16 192.2.0.1 207 Dynamic
233.252.0.5 V501-1/16 192.2.0.1 204 Dynamic
233.252.0.6 V501-1/16 192.2.0.1 209 Dynamic
233.252.0.7 V501-1/16 192.2.0.1 206 Dynamic
233.252.0.8 V501-1/16 192.2.0.1 206 Dynamic
233.252.0.9 V501-1/16 192.2.0.1 211 Dynamic
233.252.0.10 V501-1/16 192.2.0.1 207 Dynamic
10 out of 10 group Receivers displayed
Total number of unique groups 10
