Perform the following procedure to control link state changes on VLACP ports. By default, VLACP Flap Detect and Damping is disabled on all VLACP ports.
Important
Do not enable VLACP Flap Detect and Damping on Link Aggregation Control Protocol (LACP) enabled ports.
To configure VLACP Flap Detect and Damping on sub-ports, enable channelization. For more information about channelization, see Channelization.
As a best practice, to modify an existing VLACP Flap Detect and Damping configuration, first disable VLACP on the interface.
Configure VLACP Flap Detect and Damping on port 1/3:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface GigabitEthernet 1/3
Switch:1(config-if)#vlacp flap-detect enable
Switch:1(config-if)#vlacp flap-interval 120
Switch:1(config-if)#vlacp flap-frequency 6
Switch:1(config-if)#show vlacp interface gigabitethernet 1/3
                               VLACP Information
INDEX ADMIN   OPER    PORT   FAST    SLOW    TIMEOUT TIMEOUT ETHER      MAC
      ENABLED ENABLED STATE  TIME    TIME    TIME    SCALE   TYPE       ADDR
1/3   false   false   DOWN  200     30000    long     3      0x8103    01:80:c2:00:11:00
                         VLACP Flap Detect Information
INDEX FLAP    FLAP   FLAP      TOTAL    FIRST-FLAP         LAST-FLAP
      DETECT  FREQ   INTERVAL  FLAP     TIME               TIME
1/3   enable   6     120	    6       01/03/19 15:11:52  01/03/19 15:12:12
Use data in the following table to use the vlacp command.
                                 Variable  |
                                 Value  |
                                 flap-detect enable  |
                                 Enables VLACP Flap Detect and Damping on the specified port. By default, VLACP Flap Detect and Damping is disabled on all ports.  |
                                 flap-interval<10-600>  |
                                 Configures VLACP Flap Detect and Damping time interval in seconds. The default value is 60 seconds.  |
                                 flap-frequency<3-30>  |
                                 Configures the VLACP Flap count permitted during the configured time interval. The default value is 3.  |
