View the table of default routers learned from router advertisement messages.
A maximum of four routers are visible in the default routers list.
Switch:1#show ipv6 default-routers
                   Default Routers
NET ADDRESS                     VLAN   LIFETIME     IS ACTIVE
fe80::211:58ff:fe2b:fc00        mgmt     1778             YES
fe80::215:e8ff:fe6e:2800        mgmt     1657              NO
