Use trace to observe the status of IPv6 at a certain time.
Confirm that trace level 99 is set to a value of 1 before you use trace to diagnose IPv6 problems. Trace level 1 is very terse.
Caution
Risk of traffic loss
Using the trace tool inappropriately can cause CPU lockup conditions, loss of access to the device, loss of protocols, and service degradation.
Switch:1>enable
Activate the trace for all the IPv6 forwarding categories:
Switch:1#trace ipv6 forwarding enable all
Activate the trace for all the IPv6 neighbor discovery categories:
Switch:1#trace ipv6 nd enable all
Activate the trace for the all IPv6 routing table manager categories:
Switch:1#trace ipv6 rtm enable all
Activate the trace for all the IPv6 transport caterories:
Switch:1#trace ipv6 transport enable all
Deactivate the trace:
Switch:1#trace shutdown
Switch:1#clear trace
Removed 5 files.
The following table defines parameters for the trace ipv6 command.
                             Variable  |
                             Value  |
                             base <disable|enable> <all|debug|error|icmp|info|ipclient|nbr|pkt|warn>  |
                             Enables or disables a specific trace category for IPv6 base.  |
                             forwarding <disable|enable> <all|debug|error|info|pkt|warn>  |
                             Enables or disables a specific trace category for IPv6 forwarding.  |
                             nd <disable|enable> <all|debug|error|info|nbr|pkt|redirect|warn>  |
                             Enables or disables a specific trace category for IPv6 neighbor discovery.  |
                             ospf <disable|enable> <adj|all|config|error|import|info|lsa|pkt|spf|warn>  |
                             Enables or disables a specific trace category for IPv6 OSPF.  |
                             rtm <disable|enable> <all|change-list|debug|error|fib|info|redist|update|warn>  |
                             Enables or disables a specific trace category for IPv6 routing table manager.  |
                             transport <disable|enable> <all|common|tcp|udp>  |
                             Enables or disables a specific trace category for IPv6 transport.  |
                             vrf WORD<1–16>  |
                             Specifies the VRF name.  |
