Troubleshooting DHCP Relay
Configure the server to reply to the client subnet. Check the server configuration file to verify the configuration.
Configure a route on the server for the client subnet to create a path on which to send replies.
Perform this procedure to troubleshoot the DHCP relay agent.
Switch:1# ping 192.0.2.31
Switch:1:#show spanning-tree mstp port role
                           CIST Port Roles and States
Port-Index  Port-Role    Port-State   PortSTPStatus  PortOperStatus
1/1         Disabled     Forwarding   Disabled       Disabled
1/2         Disabled     Forwarding   Disabled       Disabled
1/3         Disabled     Discarding   Enabled        Disabled
1/4         Disabled     Discarding   Enabled        Disabled
1/5         Disabled     Forwarding   Disabled       Disabled
1/6         Disabled     Forwarding   Disabled       Disabled
1/7         Disabled     Forwarding   Disabled       Disabled
1/8         Disabled     Forwarding   Disabled       Disabled
1/9         Disabled     Discarding   Enabled        Disabled
1/10        Disabled     Discarding   Enabled        Disabled
1/11        Disabled     Discarding   Enabled        Disabled
1/12        Designated   Forwarding   Enabled        Enabled
1/13        Disabled     Forwarding   Disabled       Disabled
1/14        Disabled     Forwarding   Disabled       Disabled
--More-- (q = quit)
 Switch:1:# trace level 9 3
Switch:1:# trace grep 00-1A-4B-8A-FB-6B
Use the data in the following table to use the troubleshooting commands in this procedure.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 WORD<0-128>  |
 Specifies the text string to use as the search criterion.  |
 WORD<0-256>  |
 Specifies the IP address.  |
