Perform this procedure to view the UNI ports associated with particular remote IP multicast routes.
- Select SPBM Remote.
- Select the IpMcastRoutes tab.
- Select an entry.
- Select the UNI Ports button.
IpMcastRoutes-Uni Ports Field Descriptions
Use data in the following table to use the IpMcastRoutes-Uni Ports tab.
Name |
Description |
VsnIsid |
Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID. |
Group |
Specifies the group IP address for the IP Multicast over Fabric Connect route. |
Source |
Specifies the IP address where the IP Multicast over Fabric Connect route originates. |
NickName |
Specifies the nickname. |
EgressVlan |
Specifies the egress VLAN of the IP multicast route. |
EgressActivePorts |
Specifies the egress active ports. |
