This procedure only applies to VSP 4900 Series.
Perform this procedure to display information about an installed Solid State Drive (SSD) on a switch.
 - Select Chassis.
 - Select the SSD tab.
SSD Field Descriptions
Use the data in the following table to use the SSD tab.
| Name | Description |
                                 ProductName  |
                                 Specifies Solid State Drive (SSD) product name.  |
| VendorName |
                                 Specifies the SSD vendor.  |
| ManufactureDate |
                                 Specifies the date on which the SSD was manufactured.  |
| SerialNum |
                                 Specifies the SSD serial number.  |
| PartNum |
                                 Specifies the SSD part number.  |
| DeviceVersion |
                                 Specifies the version of the SSD.  |
| TotalSize |
                                 Specifies the total memory size of the SSD.  |
