Use IPv6 prefix lists to allow or deny specific route updates. A prefix list policy specifies route prefixes to match. When there is a match, the route is used.
Change the VRF instance as required to configure a prefix list on a specific VRF instance.
- In the navigation pane, open the following folders: .
 - Click Policy.
 - In the Ipv6-Prefix List tab, click Insert.
 - Edit the parameters as required.
 - Click Insert.
Ipv6–Prefix list field descriptions
Use the data in the following table to use the Ipv6–Prefix List tab.
 Name  |
 Description  |
 Id  |
 Specifies the list identifier. The range is 1 to 2147483647.  |
 Prefix  |
 Specifies the prefix IPv6 address.  |
 PrefixMaskLen  |
 Specifies the length of the prefix mask. You must enter the full 128-bit mask to exact a full match of a specific IPv6 address (for example, when creating a policy to match the next-hop).  |
 Name  |
 Names a specified prefix list during the creation process or renames the specified prefix list. The name can be from 1 to 64 characters in length.  |
 MaskLenFrom  |
 Specifies the lower bound on the mask length. The default is the mask length. Lower bound and higher bound mask lengths together can define a range of networks.  |
 MaskLenUpto  |
 Specifies the higher bound mask length. The default is the mask length. Lower bound and higher bound mask lengths together can define a range of networks.  |
