Configure the MLD on a port.
- On the Device Physical View tab, select a port.
 - Click IPv6.
 - Click the MLD tab.
 - Configure the MLD interface parameters.
 - On the toolbar, click Apply to save the changes.
 - On the toolbar, click Refresh to update the changes.
MLD field description
Use the data in the following table to use the MLD tab.
 Field  |
 Description  |
 QueryInterval  |
 Specifies the frequency at which MLD host-query packets are transmitted on this interface. Values range from 1 to 65535.  |
 Version  |
 Indicates the MLD version.  |
 Querier  |
 Specifies the address of the MLD Querier on the IPv6 subnet to which this interface is attached.  |
 QueryMaxResponseDelay  |
 Specifies the maximum query response time advertised in MLD queries on this interface. Values range from 0 to 60.  |
 Joins  |
 Specifies the number of times a group membership has been added on this interface.  |
 Groups  |
 Specifies the current number of entries for this interface in the cache table.  |
 Robustness  |
 Specifies the robustness variable tuning for the expected packet loss on a subnet. If a subnet is expected to experience loss, the robustness variable can be increased. Values range from 2 to 255.  |
 LastListenQueryIntvl  |
 Specifies the maximum response delay inserted into the group-specific queries sent in response to the leave group messages. It also indicates the amount of time between group-specific query messages. Values range from 0 to 60. This value can be tuned to modify the leave latency of the network. A reduced value results in reduced time to detect the loss of the last member of a group.  |
 SnoopEnable  |
 Indicates if snooping is enabled.  |
 FlushAction  |
 Specifies the MLD flush action as one of the following:
 SsmEnable  |
 Indicates if ssm is enabled.  |
 NewQuerier  |
 Specifies the IPv6 address of the new MLD querier.  |
 DynamicDowngradeEnable  |
 Enables dynamic downgrade of the MLD version when older version query message is received.  |
 OperVersion  |
 Specifies the operational version of the MLD running on this interface.  |
 McastMode  |
 Specifies the MLD interface mode as one of the following:
