Configure a Remote VTEP
Use the following procedure to configure the remote VTEP destination.
- Select VTEP.
- Select the Vtep tab.
- In the Id field, assign a unique index value to this remote VTEP.
- In the IpAddr field, enter the IP address of this remote VTEP.
- In the Name field, assign a name to this remote VTEP.
- Select Apply.
Vtep field descriptions
Use the data in the following table to use the Vtep tab.
Name |
Description |
Id |
Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
IpAddr |
Specifies an IP address that uniquely identifies this remote VTEP. Note:
The remote VTEP IP address cannot be a local, broadcast, or multicast IP address. |
Name |
Assigns a name to this remote VTEP tunnel. |
NextHopVrfName |
Displays the VRF name of the next hop to reach the remote VTEP. |
OvsdbConfigured |
Specifies if the VTEP is configured with OVSDB protocol support for VXLAN Gateway. |
