View information about the temperature for each sensor on the device.
The system triggers an alarm when one of the zones exceeds the threshold temperature value.
- In the Device Physical View tab, select the chassis.
 - Select Chassis.
 - Select the System Temperature tab.
System Temperature field descriptions
Use the data in the following table to use the System Temperature tab.
 Name  |
 Description  |
 SensorIndex  |
 Specifies the range of sensors on the device.  |
 SensorDescription  |
 Specifies the name of the sensor.  |
 Temperature (degrees celsius)  |
 Specifies the sensor temperature measured in Celsius degrees.  |
 WarningThreshold  |
 Specifies the temperature value of the warning threshold for the sensor. When the temperature crosses the warning threshold a warning message is generated.  |
 CriticalThreshold  |
 Species the temperature value of the critical threshold for the sensor. When the temperature crosses the critical threshold, a critical message is generated or the system shuts down, depending on hardware capability.  |
 Status  |
 Specifies the current temperature status based on the warning and critical thresholds.  |
