Globally enable or disable EAP on the switch. By default, EAP is disabled.
 - Select 802.1X - EAPOL.
 - Select the Global tab.
 - From the AccessControl options, select enable.
 - Optional: Select the appropriate NonEapRadiusPwdAttrFmt check boxes to configure the format of the RADIUS password when authenticating non-EAP MAC addresses using RADIUS.
 - Optional: Enter the key string in the NonNonEapRadiusPwdAttkeystring field.
 - Optional: Check the ClearNonEap check box to clear the NEAP session that is learned on the switch.
 - Optional: Type an I-SID offset number in the AutoIsidOffset field.
 - Optional: Select the AutoIsidOffsetEnable check box to enable Auto I-SID offset on the switch.
 - Select Apply.
Global field descriptions
Use the data in the following table to use the Global tab.
                                 Name  |
                                 Description  |
                                 EapolVersion  |
                                 Displays the EAP version on the switch.  |
                                 AccessControl  |
                                 Enables system authentication control. EAP is disabled by default.  |
                                 NonEapRadiusPwdAttrFmt  |
                                 Specifies the password attribute format for non EAP RADIUS authentication.
                                 NonEapRadiusPwdAttrKeyString  |
                                 Specifies the attribute key string for non EAP RADIUS password.  |
                                 ClearNonEap  |
                                 Clears the NEAP session that is learned on the switch.  |
| AutoIsidOffset | Specifies the Auto I-SID Offset value. |
| AutoIsidOffsetEnable | Enables or disables the Auto I-SID Offset feature. |
