The following table defines parameters for the filter acl ace policer command.
                                 Variable  |
                                 Value  |
                                 <acl-id>  |
                                 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
                                 <ace-id>  |
                                 Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.  |
                                 svc-rate <0-4000000000>  |
                                 Specifies the rate of the traffic committed to be delivered. Service rate limit in kbps {0-4000000000}.The granularity is 8 kbps.  |
| peak-rate <8-4000000000> |
                                 Specifies the value when exceeded causes packets to drop on ingress. Peak rate limit in kbps {8-4000000000}.The granularity is 8 kbps.  |
