Defining DHCP Server Global Settings
		Set a DHCP server global configuration by defining
			whether BOOTP requests are ignored and by defining DHCP global server options.
To define DHCP server global settings:
				Select the Global Settings tab and ensure that the
						Activate DHCP Server Policy button remains selected.
				This option must remain selected to
					implement the configuration as part of the access point profile. DHCP Server Policy - Add/Edit - Global
							Settings Tab
				Set the following parameters within the Configuration
					field:
									| Ignore BOOTP Requests | Select the check box to ignore BOOTP requests. BOOTP (boot
										protocol) requests boot remote systems within the network.
										BOOTP messages are encapsulated inside UDP messages and
										forwarded. This feature is disabled by default, so unless
										selected, BOOTP requests are forwarded. |
									| Ping Timeout | Set an interval (from 1 -10 seconds) for the DHCP server ping
										timeout. The timeout is the intermittent ping and discover
										interval to determine whether a client requested IP address
										is already used. |
				Set the Activation Criteria for the
					DHCP server policy:
				Use the drop-down menu
					to select the criteria from one of none,
						vrrp-master, cluster-master or
						rf-domain-manager. The default value is
						none.
				Refer to the Global DHCP Server Options field.
						Use the + Add Row button at the bottom of the
							field to add a new global DHCP server option.
						Select the radio button of an existing global DHCP server option and
							select the Delete icon to remove it from the list of those
							available.
						Use the Type drop-down menu
							to specify whether the DHCP option is being defined as a numerical IP
							address, an ASCII string, or a hex string.
						Highlight an entry from within
							the Global Options screen and click the
								Remove button to delete the name and
							value.
				Click OK to save the updates to the DHCP server global
					settings.
				Click Reset to revert the screen to its last saved
					configuration.
