IP |
Define or override the IP address used by peer access points for interoperation when supporting the MiNT protocol. |
Port |
To specify a custom port for MiNT links, select this option and use the spinner control to define or override the port number from 1 - 65,535. |
Routing Level |
Define or override a routing level of either 1 or 2. |
Listening Link |
Specify a listening link of either 0 or 1. UDP/IP links can be created by configuring a matching pair of links, one on each end point. However, that is error prone and does not scale. So UDP/IP links can also listen (in the TCP sense), and dynamically create connected UDP/IP links when contacted. |
Forced Link |
Select this option to specify the MiNT link as a forced link. This setting is disabled by default. |
Link Cost |
Define or override a link cost from 1 - 10,000. The default value is 100. |
Hello Packet Interval |
Set or override an interval in either seconds (1 - 120) or minutes (1 - 2) for the transmission of hello packets. The default interval is 15 seconds. |
Adjacency Hold Time |
Set or override a hold time interval in either seconds (2 - 600) or minutes (1 - 10) for the transmission of hello packets. The default interval is 46 seconds. |
IPSec Secure |
Select this option to use a secure link for IPSec traffic. This setting is disabled by default. When this option is enabled, both the header and the traffic payload are encrypted. |
IPSec GW |
Define either an IP address or hostname for the IPSec gateway. |
