Application Visibility
            RF Domain member devices inspect every byte of each application
                header packet allowed to pass through the WiNG managed network.
                When an application is recognized and classified by the WiNG
                application recognition engine, administrator defined actions
                can be applied to that specific application. For information on
                categorizing, filtering and logging the application data allowed
                to proliferate the WiNG managed network, refer to
Application and
Application Group.
The WiNG 7.1 release does not support DPI on
                    AP505 and AP10 model access points. This feature will be
                    supported in future releases.
            To view the application
                utilization statistics:
                Select the
                        Statistics menu from the Web UI.
                Expand the
                        System node on the top, left-hand side of
                    the screen.
The
                        System node expands to display the RF
                    Domains created within the managed network.
                Select an
                        RF
                        Domain from the list.
The RF
                    Domain statistics menu displays in the right-hand side of
                    the screen, with the Health tab selected by default.
                Select
                        Application Visibility from the RF Domain
                    menu.
                Refer to the Top Applications graph to
                    assess the most prolific, and allowed, application data
                    passing through RF Domain member devices.
                            | Total Bytes |
                            Displays the top ten RF Domain member
                                utilized applications in respect to total data
                                bytes passing through the RF Domain member WiNG
                                managed network. These are only the
                                administrator allowed applications approved for
                                proliferation within the RF Domain member
                                device. |
                            | Bytes Uploaded |
                                applications in respect to total data bytes
                                uploaded through the RF Domain member WiNG
                                managed network. If this application data is not
                                aligned with application utilization
                                expectations, consider allowing or denying
                                additional applications and categories or
                                adjusting their precedence (priority). |
                            | Bytes Downloaded |
                                downloaded from the RF Domain member WiNG
                Refer to the Application Detailed Stats table to assess
                    specific application data utilization:
                            | Application Name |
                            Lists the RF Domain member allowed
                                application name whose data (bytes) are passing
                                through the WiNG managed network. |
                            | Uploaded |
                            Displays the number of uploaded application
                                data (in bytes) passing the through the WiNG
                                managed network.  |
                            | Downloaded |
                            Displays the number of downloaded
                                application data (in bytes) passing the through
                            | Num Flows |
                            Lists the total number of application data
                                flows passing through RF Domain member devices
                                for each listed application. An application flow
                                can consist of packets in a specific connection
                                or media stream. Application packets with the
                                same source address/port and destination
                                address/port are considered one flow.  |
                Click Clear Application Stats to clear the application
                    assessment data counters and begin a new assessment.
                Periodically, click Refresh to update the statistics
                    counters to their latest values.
                Select the Category tab.
Categories are existing WiNG or
                    user defined application groups (video, streaming, mobile, audio etc.) that
                    assist administrators in filtering (allowing or denying) application data. For
                    information on categorizing application data, refer to
Application and
Application Group.
                The screen displays.
Refer to the
Top
                            Categories graph to assess the most prolific, and allowed,
                        application data categories utilized by RF Domain member
                            devices.
                                | Total Bytes |
                                Displays the top ten RF Domain member application
                                    categories in respect to total data bytes passing through the RF
                                    Domain member WiNG managed network. These are only the
                                    administrator allowed application categories approved for
                                    proliferation within the RF Domain. |
                                | Bytes Uploaded |
                                    categories in respect to total data bytes uploaded through the
                                    RF Domain member WiNG managed network. If this category data is
                                    not aligned with application utilization expectations, consider
                                    allowing or denying additional categories or adjusting their
                                | Bytes Downloaded |
                                    categories in respect to total data bytes downloaded from the RF
                                    Domain member WiNG managed network. If this category data is not
                                    allowing or denying additional categories and categories or
Refer to the
Category Detailed
                            Stats table to assess specific application category data
                            utilization:
                                | Category Name |
                                Lists the RF Domain member allowed category whose
                                    application data (in bytes) is passing through the WiNG managed
                                    network. |
                                | Uploaded |
                                Displays the number of uploaded application category data
                                    (in bytes) passing the through the WiNG managed
                                    network. |
                                | Downloaded |
                                Displays the number of downloaded application category data
                                    (in bytes) passing the through the WiNG managed network.  |
                                | Num Flows |
                                    application category data flows passing through RF Domain member
                                    devices. A category flow can consist of packets in a specific
                                    connection or media stream. Packets with the same source
                                    address/port and destination address/port are considered one
                                    flow.  |
                Click Clear Category Stats to clear the application
                    category assessment data counters and begin a new assessment.
