Device Data Transmit
To view mesh point statistics for RF Domain member APs and their connected clients:
  1. Select the Statistics menu from the Web UI.
  2. Expand the System node on the top, left-hand side of the screen.
    The System node expands to display the RF Domains created within the managed network.
  3. Select an RF Domain from the list.
    The RF Domain statistics menu displays in the right-hand side of the screen, with the Health tab selected by default.
  4. Select Mesh Point from the RF Domain menu.
    The MCX Geographical View screen displays by default.
  5. Click Device Data Transmit from the top of the screen.
    The Device Data Transmit screen displays.
  6. Review the following transmit and receive statistics for Mesh nodes:
    Data Bytes (Bytes): Transmitted Bytes Displays the total amount of data, in Bytes, transmitted by Mesh Points in the RF Domain.
    Data Bytes (Bytes): Received Bytes Displays the total amount of data, in Bytes, received by Mesh Points in the RF Domain.
    Data Bytes (Bytes): Total Bytes Displays the total amount of data, in Bytes, transmitted and received by Mesh Points in the RF Domain.
    Data Packets Throughput (Kbps): Transmitted Packets Displays the total amount of data, in packets, transmitted by Mesh Points in the RF Domain.
    Data Packets Throughput (Kbps): Received Packets Displays the total amount of data, in packets, received by Mesh Points in the RF Domain.
    Data Packets Throughput (Kbps): Total Packets Displays the total amount of data, in packets, transmitted and received by Mesh Points in the RF Domain.
    Data Rates (bps): Transmit Data Rate Displays the average data rate, in kbps, for all data transmitted by Mesh Points in the RF Domain.
    Data Rates (bps): Receive Data Rate Displays the average data rate, in kbps, for all data received by Mesh Points in the RF Domain.
    Data Rates (bps): Total Data Rate Displays the average data rate, in kbps, for all data transmitted and received by Mesh Points in the RF Domain.
    Packets Rate (pps): Transmitting Packet rate Displays the average packet rate, in packets per second, for all data transmitted and received by Mesh Points in the RF Domain.
    Packets Rate (pps): Received Packet rate Displays the average packet rate, in packets per second, for all data received and received by Mesh Points in the RF Domain.
    Packets Rate (pps): Total Packet Rate Displays the average data packet rate, in packets per second, for all data transmitted and received by Mesh Points in the RF Domain.
    Data Packets Dropped and Errors: Tx Dropped Displays the total number of transmissions that were dropped Mesh Points in the RF Domain.
    Data Packets Dropped and Errors: Rx Errors Displays the total number of receive errors from Mesh Points in the RF Domain.
    Broadcast Packets: Tx Bcast/Mcast Pkts Displays the total number of broadcast and multicast packets transmitted from Mesh Points in the RF Domain.
    Broadcast Packets: Rx Bcast/Mcast Pkts Displays the total number of broadcast and multicast packets received from Mesh Points in the RF Domain.
    Broadcast Packets: Total Bcast/Mcast Pkts Displays the total number of broadcast and multicast packets transmitted and received from Mesh Points in the RF Domain.
    Management Packets: Transmitted by the node Displays the total number of management packets that were transmitted through the Mesh Point node.
    Management Packets: Received by the node Displays the total number of management packets that were received through the Mesh Point node.
    Management Packets: Total Through the domain Displays the total number of management packets that were transmitted and received through the Mesh Point node.
    Data Indicators: Traffic Index Displays True of False to indicate whether or not a traffic index is present.
    Data Indicators: Max User Rate Displays the maximum user throughput rate for Mesh Points in the RF Domain.
    Data Distribution: Neighbor Count Displays the total number of neighbors known to the Mesh Points in the RF Domain.
    Data Distribution: Neighbor Count Displays the total number of neighbor radios known to the Mesh Points in the RF Domain.
  7. Select the Refresh button to update the screen‘s statistics counters to their latest values.
