ExtLibA.EntityMgr.EntityRepOperFail
Description
An entity replication operation failed. The entity may be disrupted if System Manager fails over.
Remedy
Investigate the cause of the replication failure. If this does not solve the problem, contact support.
Severity
Error
Message Text
An entity replication operation failed. Replication action = %p1% Replication return code = %p2% Entity type = %p3% Entity index = %p4%
Message Parameters
Name Type
p1 uInt8
p2 uInt8
p3 xInt32
p4 HexByteArray
