HAL.SM.SlowPathReroute
Description
A slow speed switch fabric link to the specified slot and unit has failed. The redundant slow speed switch fabric link (available only in dual-MM operation) has been activated.
Remedy
Please refer the event HAL.Sys.IntPortDown indicating the failed link information details. The affected I/O blade should be removed and its midplane connector inspected for damage. If none is found, the I/O blade can be reseated to see if the link recovers. If the link fails again, the affected MM should be removed and its connectors inspected for damage. If none is found, the MM should be reseated. Note that is the MM through which the reroute has taken place is removed or otherwise failed, the I/O blade will also fail.
Severity
Warning
Message Text
Slow path traffic to %ioslot% Unit-%unit% has been rerouted through %mm% due to a failed link.
Message Parameters
Name Type
ioslot String
unit uInt32
mm String
Applicable Platforms
  • I386 virtual machine switch simulator
  • BlackDiamond X8 series switches
