HAL.VSM.QualTrunkFail
Description
An attempt to qualify the specified LAG has failed. The specified return code value is provided by the low level driver which has only internal significance.
Remedy
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: - output of "show tech"
Severity
Error
Message Text
Trunk id %TGID% qualification failed on slot %slot%, unit %unit% return code %rv%
Message Parameters
Name Type
TGID uInt
slot uInt
unit uInt
rv uInt
