The type of I/O card in the specified I/O slot cannot be used with the named Fabric Mode.
Either remove the I/O card from the switch, disable it, or upgrade the fabric modules.
Warning
The %cardTypeStr% card in %slotName% is not usable in Fabric Mode %fabModeStr%. Please disable the slot, remove the %cardTypeStr% card, or upgrade the fabric modules.
| Name | Type |
| cardTypeStr | String |
| slotName | String |
| fabModeStr | String |
Print
this page
Email this topic
Feedback
